Multiple Load Cases
Dear all,
I found a suspecius visualization of the load cases.
I would like to define multiple load combinations made by gravity and additional loadings.
Strangely, the results do not look coherent with the load case name. For instance, I defined LD1 (gravity plus vertical -Z loading) but when I select LD1 in “Result-Case” it does not correspond to the definition. It seems a load index error, but I didn’t find the solution. Can you help me up with this issue?
LoadCases.gh (30.1 KB)
G
For some reason the ResCase input was set to 0, which gives errors in the DropDown Menu. When you change this to -1 the problem is fixed.
