Hello.
Is there any way to manage the duplication of load cases when using the Load Case Combinator component?
Hello @Alfredo_Peña,
thanks for this bug report! The duplicates should be automatically eliminated from the resulting list.
I added an issue here.
– Clemens
Is there any temporary workaround?
Hi @Alfredo_Peña here is a workaround. This first involves created a “hidden” load combination “W” and using that inside the ULS load combination.
Then you can decide in the Analyse component if you wish to calculate this load combination or not.
