I have a question please regarding load cases/combinations in Kiwi!3D. I tried to add 2 load cases as shown in the attached .gh file, but I am getting an error message stating the following: “Solution Exception: Load Case 2 is not part of the DataBase!”
How would I set up a couple of load cases, and then make Kiwi combine them together? Say 1.2Dead Load +1.5Snow Load.
Hey,
that feature is unfortunately not super intuitive. It sorts the load cases in increasing order. They are then in a list and the actual LC input is the index of the list. So if you have load case 10,11,21, you’ll find 10 with index 0, 11 with 1 and 21 with 2.
In order to combine them, you can just use several Result component with the respective load cases (or one with several). The results output gives you the possibility to combine them in the manner you like.
