Hello everyone,
I would like to ask, if there is an option in Rhino 7 for layers visibility to be saved together with named viewport. I know that Cplane saves with a named viewport, so maybe there is a way I can save layer visibility setting with it as well?
This feature is for example in sketchup, where you are able to save different cameras with different settings for each. Lets say I have 10 different cameras, but in each I need to have different things to be seen only. In sketchup you click different cameras and get different visibility combinations as you saved it. In Rhino, as I know, you need to change visibilities manually (with a bulbs) after you click every single named view
Is that right or am I missing something?
Thank you
