NamedEverything
Is there already a way to combine namedviews, namedcplanes, namedpositions & layerstates into one command or is this in the realms of a script or plugin?
Hi Nick - it’s hard for me, off hand, to see what advantage this would bring - can you elaborate?
thanks,
Admittedly it is a bit of an obscure request.
In designing boats with lots of parts it would be nice to quickly switch off many items (layerstates), clip other objects (namedposition of clipping planes), orient and zoom the camera correctly (namedviews) and work on the desired cplane (namedcplanes). It is not a workflow I currently use because it is long winded. But I can see a use for it as a single action. Each item could be setup individually and then combine them as needed.
