How to Project text onto an angled wall
I have an triangle cavity that I want to project a piece of text onto for engraving.
Since the wall sits at an angle I’m having problems trying to get it projected onto the wall.
I’m attaching a sample of the part, and I am also attaching a screenshot showing which wall I am trying to project the lettering ( the number “4” )
The wall I want to project the 4 onto is in yellow
Or maybe a better approach is trying to use some type of Align command?
Thank You,
Kent
Example.3dm (2.8 MB)
Hi Kent - OrientOnSrf seems like a good way - set the two reference points along one of the likes in the figure.
Rigid checked, Copy=Yes (so you keep the original)
This might be of use…
Another method
Thank You Pascal and Gerald,
I ended up using a combination of both of your suggestions and it got me where I needed to go…
Thanks again…
Kent
