How to progressive move?
Hi everyone,
I would like to know if there is any way of selecting a range of points such as control points of a surface or whatever and move them as series. Like move n in z direction and for the next point I move n+1 and so goes on.
Is this possible to do only in rhino?
I wasnt sure if it was possible to do with simple Rhino Commands. However i think this is perfect to do in Grasshopper (which is included in Rhino if you have Version 6).
I created this small script. Maybe it helps you. If you have any Questions feel free to ask.
Moving_points_re.gh (25.9 KB)
If I’m understanding your question, then yes.
  1. Turn on control points
  2. Select the subset of the ones you want to move
  3. Use the Nudge tools to move them around a little bit at a time
You can also try the SoftMove command on a selection of objects (eg: control points) or SoftEditSrf on a surface might do the trick.
