Is there a way to move an object based on the previous moved object?
I need to move many objects, each of them 1 more unit than the one before. Specifcally I need to move each curve 1 meter in z axis.
So the first curve would move 1 metre, the second curve 2 metres the third curve 3 meters and so on.
Is it possible?
First, go into Options and set your Nudge interval to 1 meter and World Coordinates. Then select all curves you want to move and hit the PageUP key on your keyboard. Everything will move up 1 meter in Z. Then with the ctrl key, DESELECT the lowest curve and hit the PageUp key again. Deselect, PageUp, deselect, PageUp, etc…
–Mitch
Thats pretty smart, thank you
