Is there a way to make slabs above show up on lower level plan? I have the plan visibility set to projection with overhead, but it’s still not showing up in the lower level.
Hi @seflorance, the “overhead” attributes of an object is only displayed when the object is located inside the limits of the level you are seeing in plan view, and the cut plane of that level is activated.
