How to make Oyler Wu screenplay?
Hello people,
I am having an exercise based on the Olyer Wu screenplay project.
This twenty-one foot long screen wall is constructed of forty-five thousand linear feet of rope strung through a series of lightweight steel frames. The wall is made from a repetitious steel framework with rope infill that varies over the length of the wall in three dimensions, forming a thickened undulating screen made up of dense line-work. In its orthographic, or ‘straight on’ view, the wall forms a meticulously organized series of patterns easily recognized by the viewer. As the viewer moves around the wall, its three-dimensional qualities reveal a more complex system of deep sectional cavities, twisting surfaces, and material densities.
I use a grid pinching to build steel frame for my structure but the problem here is that I can not find a way to create the twisting surfaces and material density based on the steel from the pinching grid.
I tried making twisted surfaces with contour on each surface but it was a nightmare. Can somebody help me?
Thank you!
Check the files below:
Grid Pinching.3dm (3.5 MB)
Grid Pinching.gh (26.7 KB)
images-screenplay
The image that you are trying to replicate is constructed by a bunch of hyperbolic paraboloid (hypar) surfaces With straight edges, built with line generatrices, within chosen boundarys of 4 lines. you have to use this as a rule to build your surfaces, so first you have to get your ‘frame’ grid, consisting of non planar quads only
