using Grasshopper.GUI;
using Grasshopper.GUI.Canvas;
using Grasshopper.Kernel;
using Grasshopper.Kernel.Attributes;
using System;
using System.Drawing;
using System.Globalization;
using System.Windows.Forms;
namespace ExtendGUI
public class ExtendGuiComponent : GH_Component
public int Num;
public ExtendGuiComponent() : base("ExtendGUI", "ExGUI", "test", "User", "tests") { }
public override void CreateAttributes()
m_attributes = new AttributesCustom(this);
protected override void RegisterInputParams(GH_InputParamManager pManager)
var name = Num == 0 ? "*" : " / ";
pManager.AddNumberParameter("0", "0", "0", GH_ParamAccess.item, 0);
pManager.AddNumberParameter(name, name, "", GH_ParamAccess.item, 0);
protected override void RegisterOutputParams(GH_OutputParamManager pManager)
pManager.AddNumberParameter("Num", "N", "Number.", GH_ParamAccess.item);
protected override void BeforeSolveInstance()
var input = 0.0;
var name = "x";
if (!Params.Input[0].VolatileData.IsEmpty)
foreach (var item in Params.Input[0].VolatileData.AllData(false))
item.CastTo(out input);
name = input.ToString(CultureInfo.InvariantCulture);
Params.Input[0].Name = name;
Params.Input[0].NickName = name;
protected override void SolveInstance(IGH_DataAccess DA)
var num0 = 0.0;
if (!DA.GetData(0, ref num0)) return;
if (Params.Input.Count < 2) return;
switch (Num)
case 0:
var num1 = 0.0;
if (!DA.GetData(1, ref num1)) return;
DA.SetData(0, num0 * num1);
break;
case 1:
var num1 = 0.0;
DA.SetData(0, num0 / num1);
break;
default:
DA.SetData(0, 0);
break;
public override bool Write(GH_IO.Serialization.GH_IWriter writer)
writer.SetInt32("Num", Num);
return base.Write(writer);
public override bool Read(GH_IO.Serialization.GH_IReader reader)
Num = reader.GetInt32("Num");
return base.Read(reader);
protected override Bitmap Icon => null;
public override Guid ComponentGuid => new Guid("90194116-a86f-4ef8-84e2-e480b3000c5b");
public class AttributesCustom : GH_ComponentAttributes
private Rectangle _buttonBounds0;
private Rectangle _buttonBounds1;
private GH_Capsule _button0;
private GH_Capsule _button1;
public AttributesCustom(IGH_Component owner) : base(owner) { }
protected override void Layout()
base.Layout();
var rec0 = GH_Convert.ToRectangle(Bounds);
rec0.Height += 44;
var rec1 = rec0;
rec1.Y = rec0.Bottom - 44;
rec1.Height = 22;
rec1.Inflate(-2, -2);
var rec2 = rec0;
rec2.Y = rec0.Bottom - 22;
rec2.Height = 22;
rec2.Inflate(-2, -2);
Bounds = rec0;
_buttonBounds0 = rec1;
_buttonBounds1 = rec2;
protected override void Render(GH_Canvas canvas, Graphics graphics, GH_CanvasChannel channel)
var extendGui = (ExtendGuiComponent)Owner;
switch (channel)
case GH_CanvasChannel.Objects:
RenderComponentCapsule(canvas, graphics, true, false, false, true, true, true);
_button0 = GH_Capsule.CreateTextCapsule(_buttonBounds0, _buttonBounds0, extendGui.Num == 0 ? GH_Palette.Black : GH_Palette.White, "Multiplied", 5, 0);
_button0.Render(graphics, this.Selected, Owner.Locked, Owner.Hidden);
_button0.Dispose();
_button1 = GH_Capsule.CreateTextCapsule(_buttonBounds1, _buttonBounds1, extendGui.Num == 1 ? GH_Palette.Black : GH_Palette.White, "Divided", 5, 0);
_button1.Render(graphics, this.Selected, Owner.Locked, Owner.Hidden);
_button1.Dispose();
break;
default:
base.Render(canvas, graphics, channel);
break;
public override GH_ObjectResponse RespondToMouseDown(GH_Canvas sender, GH_CanvasMouseEvent e)
if (e.Button != MouseButtons.Left) return base.RespondToMouseDown(sender, e);
var button = ((RectangleF)_buttonBounds0).Contains(e.CanvasLocation) ? 0 :
((RectangleF)_buttonBounds1).Contains(e.CanvasLocation) ? 1 : -1;
if (button == -1) return base.RespondToMouseDown(sender, e);
if (extendGui.Num == button)
return GH_ObjectResponse.Handled;
var name = button == 0 ? "*" : " / ";
extendGui.Params.Input[1].Name = name;
extendGui.Params.Input[1].NickName = name;
extendGui.RecordUndoEvent("button");
extendGui.Num = button;
extendGui.ExpireSolution(true);
ExtendGUI.zip (30.3 KB)
