Q : When I type numbers inside numericUpDown slides and click “Apply” button, the numbers are imported inside the grasshopper parameter, “That’s a great news !!”. However, Whenever I saved the grasshopper file, closed the rhino file, and then reopened the rhino and grasshopper file, the numericUpDown values, and the values inside the grasshopper parameter are reset.
But I want to persist all these numbers after I click “Apply” button and save the grasshopper file.
How can I solve this problem??
Here are the images and codes.
using System;
using System.Collections.Generic;
using System.Windows.Forms;
using Grasshopper.GUI;
using Grasshopper.Kernel;
using Grasshopper.GUI.Canvas;
using Grasshopper.Kernel.Attributes;
namespace RFD
public class Toolinfo : GH_Component
#region constructor
/// Initializes a new instance of the MyComponent1 class.
public Toolinfo()
: base(“Toolinfo”, “Toolinfo”,
“This Parameter gets informations of the tool. Please read the instruction before using this parameter.”,
“RFD”, “2.Toolinfo”)
ToolValue = 0;
XValue = 0;
YValue = 0;
ZValue = 0;
AValue = 0;
BValue = 0;
CValue = 0;
/// <summary>
/// Registers all the input parameters for this component.
/// </summary>
protected override void RegisterInputParams(GH_Component.GH_InputParamManager pManager)
/// <summary>
/// Registers all the output parameters for this component.
/// </summary>
protected override void RegisterOutputParams(GH_Component.GH_OutputParamManager pManager)
pManager.AddNumberParameter("Toolinfo", "Toolinfo", "Toolinfo", GH_ParamAccess.list);
#endregion
#region attributes
////////<Winidow Form Start>/////////////////////////////
public override void CreateAttributes()
m_attributes = new MySpecialComponentAttributes(this);
public class MySpecialComponentAttributes : GH_ComponentAttributes
public MySpecialComponentAttributes(IGH_Component component) : base(component) { }
public override GH_ObjectResponse RespondToMouseDoubleClick(GH_Canvas sender, GH_CanvasMouseEvent e)
(Owner as Toolinfo)?.DisplayForm();
return GH_ObjectResponse.Handled;
#endregion
#region UI overrides
RFD.Form1 _form;
public void DisplayForm()
// Don't show the form more than once per component.
//if (_form != null)
// return;
if (_form != null)
{ return; }
_form = new Form1();
_form.FormClosed += OnFormClosed;
_form.button1.Click += button1_Click;
/// ""Use these line if you want to use TrackBar as a realtime input""
/// _form.trackBar1.ValueChanged += trackBar1_ValueChanged;
GH_WindowsFormUtil.CenterFormOnCursor(_form, true);
_form.Show(Grasshopper.Instances.DocumentEditor);
private void button1_Click(object sender, EventArgs e)
Button button = sender as Button;
ToolValue = Math.Round((double)_form.numericUpDown1.Value);
XValue = Math.Round((double)_form.numericUpDown2.Value, 1);
YValue = Math.Round((double)_form.numericUpDown3.Value, 1);
ZValue = Math.Round((double)_form.numericUpDown4.Value, 1);
AValue = Math.Round((double)_form.numericUpDown5.Value, 1);
BValue = Math.Round((double)_form.numericUpDown6.Value, 1);
CValue = Math.Round((double)_form.numericUpDown7.Value, 1);
ExpireSolution(true);
/// private void trackBar1_ValueChanged(object sender, EventArgs e)
/// TrackBar trackBar = sender as TrackBar;
/// if (trackBar != null)
/// Value = trackBar.Value;
/// ExpireSolution(true);
private void OnFormClosed(object sender, FormClosedEventArgs formClosedEventArgs)
_form = null;
/// <summary>
/// Override this function if you want to insert some custom menu items in your derived Component class.
/// Items will be added between List Matching items and parameter menus.
/// </summary>
protected override void AppendAdditionalComponentMenuItems(ToolStripDropDown menu)
Menu_AppendItem(menu, "Show UI", ShowUiClicked, null, true, false);
private void ShowUiClicked(object sender, EventArgs e)
DisplayForm();
////////<Winidow Form End>///////////////////////////////
#endregion
/// <summary>
/// This is the method that actually does the work.
/// </summary>
/// <param name="DA">The DA object is used to retrieve from inputs and store in outputs.</param>
protected override void SolveInstance(IGH_DataAccess DA)
double ToolNumber = Math.Round(ToolValue);
double Xmove = Math.Round(XValue, 1);
double Ymove = Math.Round(YValue, 1);
double Zmove = Math.Round(ZValue, 1);
double Aangle = Math.Round(AValue, 1);
double Bangle = Math.Round(BValue, 1);
double Cangle = Math.Round(CValue, 1);
List<double> toolInfo = new List<double>();
toolInfo.Add(Xmove);
toolInfo.Add(Ymove);
toolInfo.Add(Zmove);
toolInfo.Add(Aangle);
toolInfo.Add(Bangle);
toolInfo.Add(Cangle);
toolInfo.Add(ToolNumber);
DA.SetDataList("Toolinfo", toolInfo);
public double ToolValue { get; set; }
public double XValue { get; set; }
public double YValue { get; set; }
public double ZValue { get; set; }
public double AValue { get; set; }
public double BValue { get; set; }
public double CValue { get; set; }
/// <summary>
/// Provides an Icon for the component.
/// </summary>
protected override System.Drawing.Bitmap Icon
get
return RFD.Properties.Resources.ICON_8_ToolInfo;
/// <summary>
/// Gets the unique ID for this component. Do not change this ID after release.
/// </summary>
public override Guid ComponentGuid
get { return new Guid("b72bb830-a0b4-4d53-98a2-81834631d33c"); }
