Custom component with toggle button loses the value when file closes
Hello there,
I have developed a component that integrates a toggle button. Given two numerical buttons, the toggle button adds/subtracts the values. Everything works well but when saving the file and opening it again the toggle button returns to a default value (e.g. “subtract”), even though when the file was saved according to the button the values were added. How do I make sure that the toggle value is saved when I close the file?
Thank you,
You need to write your value and read it using those overrides.
https://developer.rhino3d.com/api/grasshopper/html/Methods_T_GH_IO_GH_ISerializable.htm
Example with a boolean below.
private bool m_fa = false;
public bool fa
    get
        return this.m_fa;
    set
        this.m_fa = value;
public override bool Write(GH_IWriter writer)
    writer.SetBoolean("fa", this.fa);
    return base.Write(writer);
public override bool Read(GH_IReader reader)
    reader.TryGetBoolean("fa", ref this.m_fa);
    return base.Read(reader);
indeed… magnifique, merci!
