Good morning. I am hoping someone can humour me by helping out with a problem I am having.
I have made a slider component with custom attributes in visual studio:
The reason is because its behavior differs slightly from the default slider and knob components.
The output value in class inheriting GH_Param serializes with no problem. However, the slider value in class inheriting GH_Attributes always resets upon file reopen or pasting. I will continue to try to untangle this myself but I would be so grateful if anybody decided to give input on this problem.
Thank you.
using System;
using System.Diagnostics;
using System.Drawing;
using System.Drawing.Drawing2D;
using Grasshopper.GUI;
using Grasshopper.GUI.Canvas;
using Grasshopper.Kernel;
using Grasshopper.Kernel.Types;
public class Looping_SliderComponent : GH_Param<GH_Number>
public Looping_SliderComponent() :
base(new GH_InstanceDescription("Looping Slider", "Nickname", "Description", "Params", "Input"))
public override void CreateAttributes()
m_attributes = new Looping_SliderComponentAttributes(this);
protected override Bitmap Icon
get
//TODO: return a proper icon here.
return null;
public override GH_Exposure Exposure
get
return GH_Exposure.primary | GH_Exposure.obscure;
public override System.Guid ComponentGuid
get { return new Guid("15904C26-A453-4331-AE26-E543CCF3968E"); }
private double m_value = 6;
public double Value
get { return m_value; }
set { m_value = value; }
protected override void CollectVolatileData_Custom()
VolatileData.Clear();
AddVolatileData(new Grasshopper.Kernel.Data.GH_Path(0), 0, new GH_Number(Value));
public override bool Write(GH_IO.Serialization.GH_IWriter writer)
writer.SetDouble("Value", m_value);
return base.Write(writer);
public override bool Read(GH_IO.Serialization.GH_IReader reader)
m_value = 0;
reader.TryGetDouble("Value", ref m_value);
return base.Read(reader);
public class Looping_SliderComponentAttributes : GH_Attributes<Looping_SliderComponent>
public Looping_SliderComponentAttributes(Looping_SliderComponent owner)
: base(owner)
public override bool HasInputGrip { get { return false; } }
public override bool HasOutputGrip { get { return true; } }
private double mouseX;
private bool clickingX;
private bool mouseOverX;
private double changeX;
private double startX;
private Region xRegion;
//Our object is always the same size, but it needs to be anchored to the pivot.
protected override void Layout()
//Lock this object to the pixel grid.
//I.e., do not allow it to be position in between pixels.
Pivot = GH_Convert.ToPoint(Pivot);
Bounds = new RectangleF(Pivot, new SizeF(200, 30));
public override GH_ObjectResponse RespondToMouseDown(GH_Canvas sender, GH_CanvasMouseEvent e)
if (e.Button == System.Windows.Forms.MouseButtons.Left)
if (xRegion.IsVisible(e.CanvasLocation))
mouseX = e.CanvasX;
clickingX = true;
Owner.ExpireSolution(true);
return GH_ObjectResponse.Capture;
return base.RespondToMouseDown(sender, e);
public override GH_ObjectResponse RespondToMouseMove(GH_Canvas sender, GH_CanvasMouseEvent e)
if (clickingX)
changeX = e.CanvasX - mouseX;
return GH_ObjectResponse.Ignore;
mouseOverX = true;
if (mouseOverX)
mouseOverX = false;
return GH_ObjectResponse.Release;
return base.RespondToMouseMove(sender, e);
public override GH_ObjectResponse RespondToMouseUp(GH_Canvas sender, GH_CanvasMouseEvent e)
if (clickingX)
startX += changeX;
changeX = 0;
clickingX = false;
return base.RespondToMouseUp(sender, e);
public override void SetupTooltip(PointF point, GH_TooltipDisplayEventArgs e)
base.SetupTooltip(point, e);
e.Description = "Double click to set a new integer";
protected override void Render(GH_Canvas canvas, Graphics graphics, GH_CanvasChannel channel)
if (channel == GH_CanvasChannel.Objects)
double posX = startX + changeX;
double myValue = Math.Round(posX / 50, 2);
Owner.Value = myValue;
//Drawing tools.
Brush defaultGray = new SolidBrush(Color.FromArgb(255, 50, 50, 50));
//Render output grip.
GH_CapsuleRenderEngine.RenderOutputGrip(graphics, canvas.Viewport.Zoom, OutputGrip, true);
//Render capsules.
RectangleF scrollCanvas = new RectangleF(Pivot.X, Pivot.Y, 200, 30);
GH_Capsule scrollCanvasCapsule = GH_Capsule.CreateCapsule(scrollCanvas, GH_Palette.White, 30, 0);
scrollCanvasCapsule.Render(graphics, Selected, Owner.Locked, false);
scrollCanvasCapsule.Dispose();
RectangleF textCanvas = new RectangleF(Pivot.X + 20, Pivot.Y + 33, 60, 20);
GH_Capsule textCanvasCapsule = GH_Capsule.CreateCapsule(textCanvas, GH_Palette.White, 10, 0);
textCanvasCapsule.Render(graphics, Selected, Owner.Locked, false);
textCanvasCapsule.Dispose();
//Render graphics.
RectangleF bounds = new RectangleF(Pivot.X + 20, Pivot.Y + 5, 160, 20);
GraphicsPath boundsPath = new GraphicsPath();
boundsPath.AddRectangle(bounds);
xRegion = new Region(boundsPath);
for (int xLoop = 0; xLoop < 6; xLoop++)
double count = 1 + Math.Floor(Math.Abs(posX) / 100);
double pos = (Pivot.X) + (((count * 100) + posX + xLoop * 30) % 180);
RectangleF balls = new RectangleF((float)pos, Pivot.Y + 5, 20, 20);
graphics.FillEllipse(Brushes.Azure, balls);
graphics.DrawString(Math.Round(myValue, 2).ToString(), GH_FontServer.Standard, defaultGray, new PointF(Pivot.X + 28, Pivot.Y + 34));
