How to invoke Manage Model Object collection?
Hi all, I referenced several objects in the tekla model (node Model Object).
And now I want to add some new objects to this set.
But the window “Manage Model Object collection” doesn’t show up.
How to invoke this window?
Thanks in advance
Hi Zelya,
I don’t think this has ever worked with Tekla objects. The way I would modify the referenced set of objects is to select the Model Object param, which will select the objects in Tekla. Then add or remove selected objects in the Tekla window. And finally right-click the Model Object param again and “Set Multiple Objects”. This will immediately reference all the currently selected objects from Tekla, just make sure you’re using the latest (1.19) version of the link.
Cheers,
Sebastian
