Set Multiple Model Objects - problem
Hi Sebastian
I downloaded the latest version of the TeklaLiveLink component and noticed that when I want to select multiple objects in Tekla via “Set Multiple Model Objects” it works fine sometimes and other times I have to call the command several times. In the previous version there were no such problems. Sebastian, am I right?
Hi Chris,
If you’ve got something valid selected in the Tekla model when triggering the command, It’ll reference in the selected objects immediately. This is more aligned with how selection from Rhino works, but of course different from how it’s worked before with Tekla.
Let me know if this alone doesn’t seem to explain what you’re experiencing.
Cheers,
Sebastian
I will try to select two beams in tekla and I must to right click on component Model Object a few times to must have possibility to select object in Tekla
