Hi I want to Filet Edge a long continuous edge, but with the command, I got this result. Some edges worked, but some have the protruded edge. Any tips could be greatly appreciated!!
The simplest way is to add some tiny radius fillet to the vertical edges, thus they will act as a guide for the large fillets at the bottom.
Another option is to split the resulting fillets where the vertical walls end (or manually set those vertical fillets to 0, which ends them in the intended place), and then create revolved fillets manually.
Third solution is to split the failed fillets, then extend (Type=Line, Merge=No or Merge=Yes), then split the excess portion of both surfaces.
I made a quick video tutorial showing those solutions step by step:
In these cases a solid modeler at Catia would be needed.
Rhino’s fillets are still too weak.
Waiting Rhino 20. ![]()
I disagree. Rhino 18 will have those. ![]()
NX software is also excellent
By the time Rhino 18 (or 20) comes out I’ll already be dead!
The first solution does the perfect job!! Thanks you so much!!
P.S. How do move the camera? They look so smooth and precise
I use a 3d mouse called SpacePilot. It’s a huge time saver and relief for the right hand, as well.
