Rhino FilletEdge help
I’m following a Rhino FilletEdge tutorial, but I can’t get the same result as the instructor. If you take a look at the bottom of the screenshot, the instructor’s’s fillet blends smoothly into the curved end, while mine ends abruptly in a straight vertical edge (top of the screenshot). I’m using the same geometry (rectangle with filleted corners, later extruded as per tutorial), same radius,… basically the same steps, but I may be missing something like ChainEdges, variable radius/handle editing, or a different edge selection. I have also attached the part of the tutorial when this happens. What am I missing or doing wrong?
Thank you in advance.
Can you share your file?
Sure. Here you go. File attached.
hardware base.3dm (6.1 MB)
Same here. I would also be interested in a solution for that.
Better try to lay off the “solid modelling tools”, and just use what Rhino was made for - NURBS surface modelling - and so, FilletSrf and Trim do the job just fine.
Older or “enterprise” version may have some bug that are solved in newer ones.
No. Its in Rhino 8 latest…
I think the way to do this is indeed with FilletSrf, followed by Trim. Start with making the four filleted surfaces and switch the options Trim and Extend off:
Next, scale the fillet surfaces out in the X-direction by dragging the red square gumball handle:
Last select the base surface and the fillets and Trim away the excess on both:
Optionally Join all the parts to make a closed polysurface:
instead of scaling - and more universal for non-planar surfaces:
use the extend option of _filletSrf followed by _UntrimAll.
happy modelling - kind regards - tom
Another question: is there a difference between the Mac (as seen in video) and Windows versions in the way it works, maybe?
Yes, of course that is what the user is forced to do.
The real question is: Why is the extended fillet trimmed in the first place? Who thought that was a good idea? When is that ever useful to the user?
What it means for the user (as this example demonstrates) is the user most often has to untrim the trimmed end. The odds that the trimmed end resulting from the Extend option will be a useful edge that can be joined to another surface edge is close to zero. If the user wants a trimmed edge that can be joined to another surface the user will have to do that trimming so what’s the point of providing a useless trim?
