How to extrude with a curve shape instead of a straight line
Hello! I’m new at rhino and I want to make like a 3D cactus. Right now I’ve been able to extrude it but like in straight line but I want to do the extrusion with a curve instead of a straight line so with this looks more like a cactus.
Thanks!
Cactus.3dm (160.9 KB)
You can draw the cross section curve and use sweep1 command to create the filleted edge
You can also extrude straight and fillet the corners. Using “filleted get” command . Make sure he radius is less than half of your extrusion height.
The third step (my favorite) is to use extrude as subd.
also If you want to invest 1 hour getting a huge jump start into rhino I recommend this video
Thanks a lot! And for example if I want to create the cactus with a curve shape instead of flat what should I do? Should I creat a semi circle 90° opposite and then use the extrude curve along curve command?
Here is my approach to the model using basic nurbs tools
Cactus.3dm (1.7 MB)
