How to edit groups?
Lets say I group a set of curves, is there anyway I can re-position/edit those curves individually without ungrouping them? I have been working in sketchup lately and their group editing ability seems really useful. I know that I can block the curves and then edit the block, but one thing I’ve run into is that you can’t reference blocked geometry from grasshopper. And I would prefer not to have to consolidate my geometry by putting them into layers. Any solutions?
Hi Lawrence - hold Shift-Ctrl and click to select within a group. Or subobjects like edges or faces in a single object.
There are also buttons for adding and removing items from a group.
what’s more, if blocks behave the way you like, you can use the Human add-on for grasshopper to automatically gain access to their inner geometry.
Groups is not Blocks - just saying’ :smile:
Is there anything like “group edit” (I like the way sketchup does their groups). Maybe its just me, but I feel like it is a commitment to make something a block. I guess it is okay to have a bunch of unique and generically named blocks then?
Hi Lawrence- in Rhino, think of groups as named selection sets - not sure what you mean by ‘group edit’.
So blocks is the way to go then? In sketchup, you can group things, but then click in to edit the contents of the group- sort of like blockedit.
Hi Lawrence - you can reach into a group with Ctrl-shift click… does that help? Blocks are the way to go if you need block functionality, groups are the way to go if you need selection sets.
The ctrl-shift click function definitely has helped me, but I agree that blocking is probably the way to go.
Thanks
Coming from sketchup too, I agree make group tool is very useful in sketchup, especially visibility settings that allows to easily hide/unhide the context. And the fact that you can do it without commiting to a block
In Rhino I put related objects in a new layer when I want to “group” the objects for visibility, color, material, etc but be able to alter individual objects geometry and location. Does SketchUp have an equivalent to Layers in Rhino?
Hi, has there been any developments in this regard ? I’m just starting in Rhino and I’m used to Sketchup and using their group functionality to separate elements while I’m working on them. Is there something similar to Sketchups “Outliner” in Rhino ?
You should look into blocks instead
I’ve been using this plugin for a while, really handy, you can edit both blocks and groups-
Block Edit New | Food4Rhino
This blockeditnew is a huge productivity improvement - especially the groupedit command. Would be essential to implement as standard command in rhino9 ! Its a much more flexible way of organizing a file, next to layers, because group contents can be selected whilst ‘outside’ the group, and this is not the case for blocks. Also the greying out (locking the rest), or isolating (hiding the rest) option is very useful for working on parts of a model. should not be extremely complex im guessing.. hoping it can be implemented!
Agree 100% but last time I was told by the developers there were enough ways to work with groups in Rhino already… :man_shrugging: which I obviously strongly disagree with.
I’m fine using the plugin for the time being but I’m dreading the day some future Rhino update breaks its functionality and the plugin developer will stop updating it. Because going back to the old ways would feel like losing an arm.
