Wish: Double click to edit inside groups
I would like to being able to edit things inside group by double click on it like it happens in Illustrator or DTP software and similar to linked blocks.
Would be good also to have a visual effect showing that the geometry are grouped and not joined. Many students doesn’t understand the difference and this drive them in to big trouble.
@Gijs do you think it makes sense?
Example: when I have many object grouped together (a table with chair) but I need to give slightly movement to each of them I have to un group them do the changes and then group them again but I’ve the risk of including other unwanted geometry.
@skysurfer in Rhino 8 you should be able to select objects in a group with subobject selection holding ctrl shift. Does this help?
This makes a lot of sense.
Still for some users could be nice to have double click groups editing and group special visualization.
but you can’t select subobjects in groups, is there no way to do that without ungrouping and such?
The BlockEditNew plugin supports exactly this - open blocks AND groups with a double click.
https://www.food4rhino.com/en/app/block-edit-new
This! That plugin is exactly how Rhino SHOULD treat groups and blocks
I agree, having to ungroup all, remove from group to edit something, and then having to group back…
But it’s going to be a challenge to edit objects that “intersect groups”… groups can be a mess if you are not careful.
I use groups a lot too, another method to be organised with many objects is using NamedSelections, I have found this very useful
