How to deal with high density meshes - speed up viewport
Hey, when using meshes like this, Rhino dramatically slows down. Is converting into blocks a fair strategy? Or is there a faster responsive way of doing this. Know in Modo it is called “static meshes”, you would not be able to edit them. But viewport performance would increase a lot.
Or is there something like working with instances in Rhino?
Thanks a lot!
Hey is there a way to deal with meshes in Rhino, working with plants in projects especially is so tiring slow and lagging.
Many thanks for any advice!
Hi Hannes - you can set the display mode to use bounding box display for dynamic drawing.
You can also try Joining meshes that share a material - if there are many separate mesh objects that can be joined into one, that should also help.
Will try it. You are a life-saver!
Thank you @pascal
