Hi
I heard that Rhino 7 run Cycle Render Engine.
I need help to create velvet material in Rhino 7. (physical material)
Thank
Travis
Hi
Thank
Travis
so, what have you tried so far?
Hi
I don’t know. Can you give suggestion
Thank
Travis
Hi @nathanletwory
I try apply it for pillow
Thank
Travis
You’ll have to play with the settings for roughness, anisotropy and sheen to get closer to what you need.
Remember also that environment and lighting play a role in how good a rendered material looks like.
The physically based material follows
https://docs.blender.org/manual/en/latest/render/shader_nodes/shader/principled.html
There are some minor differences in naming and allowed values, but otherwise document still holds up well.
Thank a lot Nathan
