Help: Construct a material with a gradient diffuse texture
Hi guys, I am trying to bend my head around Rhino and it’s materials.
And even though I am able to add and remove materials I feel that I am missing something.
1- what is the difference between a sc.doc.Materials and and a sc.doc.RenderMaterials ?
2- what is the best and simplest way for me to add a material for Rhino 7 / 8?
What I need is a material with a gradient texture.
@nathanletwory I know I have asked you before, but I could not find nor navigate the answers. So sorry for being a bit thick, but it is a difficult thing to master :slight_smile:
sc.doc.Materials = oldskool, confusing, don’t use
sc.doc.RenderMaterials = modern, relatively sensible use
https://jesterking.github.io/rhipy/
Just put in the base color channel for PBR a gradient texture. Manual stuff: Creating a tinted gradient on a glass material in Rhino
Thanks! That helps me in making a PBR (and I see we still have to convert that to a sc.doc.RenderMaterials.Add()
And I think I have made a gradient, but I don’t understand how I can put it somewhere, as pbr.BaseColor doesn’t accept it…
### MAKE PBR MATERIAL
### PBR generation by @nathanletwory
import Rhino as rh
import Rhino.Render as rr
import Rhino.DocObjects as rd
import scriptcontext as sc
def makeGradient():
    import Rhino
    g = Rhino.Display.ColorGradient()
    colors = []
    colors.append(rs.coercecolor((255,0,0)))
    colors.append(rs.coercecolor((0,255,0)))
    colors.append(rs.coercecolor((0,0,255)))
    colorStops=[]
    for i in range(len(colors)):
        colorStops.append(Rhino.Display.ColorStop(colors[i], i / (colors.Count - 1.0)))
        g.SetColorStops(colorStops)
        #g.StartPoint = rs.coerce3dpoint((0,0,0))
        #g.EndPoint = rs.coerce3dpoint((100,0,0))
        g.GradientType = Rhino.Display.GradientType.Linear
    print g
    return g
### <<used guids>>
bitmap_texture_type_guid = rr.ContentUuids.BitmapTextureType
pbr_material_type_guid = rr.ContentUuids.PhysicallyBasedMaterialType
### <<create bitmap texture>>
bmtex = rr.RenderContentType.NewContentFromTypeId(bitmap_texture_type_guid)
bmtex.Filename = "C:\\Users\\Nathan\\Pictures\\uvtester.png"
simtex = bmtex.SimulatedTexture(rr.RenderTexture.TextureGeneration.Allow)
### <<create pbr material and jump through hoops>>
# first create an empty PBR material
pbr_rm = rr.RenderContentType.NewContentFromTypeId(pbr_material_type_guid)
# to get to a Rhino.DocObjects.PhysicallyBasedMaterial we need to simulate the
# render material first.
sim = pbr_rm.SimulatedMaterial(rr.RenderTexture.TextureGeneration.Allow)
# from the simulated material we can get the Rhino.DocObjects.PhysicallyBasedMaterial
pbr = sim.PhysicallyBased
### <<set PBR properties and texture>>
# now we have an instance of a type that has all the API you need to set the PBR
# properties. For simple glass we set color to white, opacity to 0 and opacity
# IOR to 1.52
pbr.Opacity = 0.0
pbr.OpacityIOR = 1.52
pbr.BaseColor = rh.Display.Color4f.White
### ADD GRADIENT BUT WHERE AND HOW TO PLACE IT?
gradient = makeGradient()
pbr.SetTexture(simtex.Texture(), rd.TextureType.PBR_BaseColor)
### <<convert into render material>>
# convert it back to RenderMaterial
new_pbr = rr.RenderMaterial.FromMaterial(pbr.Material, sc.doc)
# Set a good name
new_pbr.Name = "My Own PBR Glass"
# Add it to the document
sc.doc.RenderMaterials.Add(new_pbr)
OK, So I managed to swap out your bitmap texture with a gradient, but it ends up as a temporary bitmap texture instead of a Gradient texture.
Can I find a way so Gradient Texture is used instead, so that I can set the two colors?
Here is where I am at now:`
You can see my altered code under “HOLO”.
(PS! def makeGradient(): is not in use now)
import Rhino as rh
import Rhino
def makeGradient():
    import Rhino
    colors = []
    colorStops=[]
        percent = i / (colors.Count - 1.0)
        colorStops.append(Rhino.Display.ColorStop(colors[i], percent))
    print dir(g)
    return g
### <<used guids>>
# IOR to 1.52
pbr.Opacity = 1
### NATHAN
#bmtex = rr.RenderContentType.NewContentFromTypeId(bitmap_texture_type_guid)
#bmtex.Filename = "C:\\Users\\Nathan\\Pictures\\uvtester.png"
#simtex = bmtex.SimulatedTexture(rr.RenderTexture.TextureGeneration.Allow)
#pbr.SetTexture(simtex.Texture(), rd.TextureType.PBR_BaseColor)
### HOLO
gradient_texture_type_guid = rr.ContentUuids.GradientTextureType
gradienttex = rr.RenderContentType.NewContentFromTypeId(gradient_texture_type_guid)
print dir(gradienttex)
simgrad = gradienttex.SimulatedTexture(rr.RenderTexture.TextureGeneration.Allow)
### ADD GRADIENT TO PBR
pbr.SetTexture(simgrad.Texture(), rd.TextureType.PBR_BaseColor)
### IT WORKS BUT TURNS OUT BLACK TO WHITE AND IS A BITMAP TEXTURE
### How can I
### HOW CAN I CHANGE THOSE COLORS?
# Set a good name
new_pbr.Name = "DTM_material"
You need to create a GradientTexture instead of a BitmapTexture. In my code I am using
So instead of BitmapTextureType you need to look for GradientTextureType (ContentUuids.GradientTextureType Property).
Further you can use the SetParameter method on rendercontent to set values for parameters. To find out the names of the two color inputs you want to either save out a render texture to disk and open in a text editor, or use something like https://jesterking.github.io/rhipy/inspect_rendermaterial_parameters.html adapted for RenderTextures instead of RenderMaterials.
Thanks, but isn’t that what I do here?
### HOLO
Ah, I looked only at the top of the script :slight_smile: Better leave the unnecessary bits out so you and I don’t get confused.
But instead of doing the display color stops just set the parameters for the gradient texture gradienttex.SetParameter(....
Thanks, I’ll try that.
Right now I am working on a UTM to NTM converter, but RhinoCode is biting me all the time, it’s buggy and struggles with rhinoscriptsyntax etc. Trying to be an early adopter isn’t easy, but it can be rewarding as heck!
