This version has errors suppressed.
Hi, greetings from 2022.
I have been trying this process in these days. Some floors were generated successfully, but some are not. Do you know what could be the problem?
Hi @c.zou,
Are you on v1.9 and using the ‘ Host Sub Elements’ component?
Keep in mind that looking the floor from Top view all the points should be inside or on the floor boundary.
Manifique ! I’ve tried v1.9 and your method, it works perfectamente
this looks perfect will be trying this !
Thank you,
Hello everyone,
I juste wanted to thank you all at mcneel for answering and helping. with this.
I have always been a rhino fan and we are now using it much more intensively in the office.
Our office is based in paris, Richez_Associés
And the project i was working on two years ago (the one mentionned in this thread) is built !
Rhino changed a lot of things and helped us a lot with our client and partners.
Here’s the project if you are interested. L’aménagement de la Porte de la Chapelle | Richez_Associés.
If you want to see pictures of the built project in detail i can show you.
Anyways, thanks and cheers to all of you working at Mcneel
Hi @kike @Japhy ! I’ve been trying to modify floor’s points using Host shape component, but I keep getting same error, component doesnt work for me.
I’m using the solution that I wrote before and it was working fine, but since some time I cant create even simplest slanted floor… Could you help me out? does the component work for you?
There was a recent fix in regard to points are on the edge tolerances, please update to the latest RiR/Rhino.
