Revit Sloping Floor
Hi Guys,
Is there a way that I can generate a sloped revit floor as per image attached?
thanks
There are some particular challenges to doing this programmatically.
https://jeremytammik.github.io/tbc/a/1121_create_sloped_floor.htm
This is the closest thing at the moment.
Thank you guys, I will try this, cheers for your help.
I guess there are no news in this sense in the Rhino.Inside isn’t it?
A sloped floor in revit is so painful to model and I would consider it a great asset in rhino.inside if it would be possible to model it in Rhino and get it correctly in Revit, without too many workarounds.
Per the Jeremy Tammik link above this is going to be challenging unless there are additions to the Revit API or specialized components are created.
