How to create a surface from overlapping curves?
Hello all,
Sorry if this is a simple question that already has an answer somewhere. I tried to search for one but couldn’t find anything that worked well. I am trying to basically run a curve boolean command on these curves I generated in gh. Attached is a photo of the script and the curves in Rhino. The surface to the right is what I produced manually but I would like to be able to generate it in grasshopper so I can extrude it. Any help is appreciated.
Thank you!
Without icons:
3. Attach minimal versions of all the relevant files
@martinsiegrist, can you please tell me what these two components are? I don’t read icons.
Thanks
Move and array polar
Ah, so. Very nice, thank you.
