How to connect points and re-arrange the points for labeling
hello
im trying to connect the points as shown in the yellow line in 2nd picture & im trying to give labeling of re arranged numbers above each point as shown in 3rd picture , can any one please help . thank you
connecting poinnts doubt.gh (9.2 KB)
this might be a way in this specific case
connecting poinnts doubt_Re.gh (10.5 KB)
depending on how you connect them to the Merge component, and to which A/B list you reverse, you can get different sortings
connecting poinnts doubt edited v0 Clipper.gh (18.8 KB)
Hi inno
thank you for your answer
thank you for you help quan li
can you please help me with this too ?
im trying to keep all the points in 1 group as shown in the 3rd picture , could you please help. thank you
grouping points.gh (976.4 KB)
this looks like the result of sections of Breps (pipes) and planes
the issue is that a plane is infinite, so it’s putting on the very same branch things that belong to one side, but also things that belong to the other :slight_smile:
I’d suggest to use brep | brep section istead, with planar surfaces created “ad-hoc” to intersect just the geometries of interest, or to attach the actual GH definition you portrait here, with internalized geometries
[edit] This might also work, but something weird is going on here:
grouping points_Re.gh (984.5 KB)
grouping points edited v0.gh (1001.0 KB)
Good for exercise, but sorting processes like this have absolutely no value in terms of the right GH workflow.
