I haven’t found a solution on the forums -any help would be greatly appreciated. Unrelated/Related I’m working on a curtain wall model and have run into an issue getting the points I need to continue modeling. I’ve come across some similar post but either the result wasn’t what I was looking for after giving it a try or I laced the inputs to use those tools.
The closest I’ve come to getting the points I’m after is sorting by plane; however this still has points out of order. My end goal is to take 4 points generated from the upper and lower horizontal member and connect them (third picture).
Internalized section of code attached.
sortfromtrim.gh (113.7 KB)
