Hello Guys!
I am quite new to grasshopper and was wondering if some one can give me a tipp
I created two lists of points and would like to connect the points to each other as shown in the screenshot I attached
without haveing this kind of connection
Many thanks Hassib
Hi Hassib,
This kind of problem is very dependant on your data structure. If you attach an example of your GH file, remember to internalise any referenced geometry, I’m sure someone will be able to help you out with an answer.
Hi Rahul
thank you for notifying me about that, this is the GH file
Test.gh (15.0 KB)
I’ve revised your definition to make it easy to understand in terms of point order…
Thanks Kim!
