How to change the topology of a cylinder?
I wanted to change the topology of a cylinder, so that the edges form 45º instead of being parallel and perpendicular to the ground.
Is it possible from Grasshopper, or is there a plugin?
Thanks
Have a try Lunchbox or Ngon plugin…
Without plugin you can use diagonalize from Kangaroo>Mesh tab
diagonal.gh (6.1 KB)
Thank you!
And, is it possible that they form 30, 75… degres instead of just 45?
Edit: I have seen that there are UVs with the plugins
That’s just depending on the aspect ratio of the square grid generated from the U & V division count.
The angle will be a function of the ratio of u/v divisions and the height/radius of the cylinder.
I wanted to say that the vertex of the diamons are not in the same vertical collumn.
Like rotating the full grid.
I tried modifying the UVs of the other plugins, but you get the same results, the vertex are always aligned in a vertical collumn.
That would only be possible for certain angles if you want the pattern to be continuous across the seam.
For arbitrary angles the grid won’t match up
cylinder_modulo.gh (12.5 KB)
cyl_00001
Thank you :full_moon_with_face:
