I am trying to edit a circular surface so I can make the form appear wavy, a curvilinear wave sloping up and down . I’m not sure the best way to do this. I thought if I could divide the circle edge into points and move the points up or down to manipulate the surface and achieve the desired result.
How could I start by going about making this geometry?
For context : I am trying to create a site orientation diagram and in this case, I thought about placing the space in the ground, with stairs around the outside descending into the interior, I don’t want to create stairs for a simple diagram, but I thought a slope would be good
As I say, I am a noob to grasshopper and not sure where to start, I can imagine a work flow of what could produce my desired effect but not sure on the syntax/ usage of commands.
Thank you for any response! much appreciated
