Does anyone know how to design (by grasshopper) a 3D cylinder with elongated Voronoi. That means when you look from top view it will look like a point, but from front view looks like a rectangle. I have attached an example pic of the Voronoi type. Any help would be much appreciated. Thank you in advance.
You can map a pattern in an elongated form by deforming it from a base rectangle to the target surface, and varying the aspect ratio of that rectangle. You can also use this approach to vary the size in one axis, which gets mapped to the u or v direction of the target surface
