Is there anyway I can change the displayed color of selected objects?
By default in rhino it would be highlighted as bright yellow when I select some points.
But I would like it not to highlight the objects I select…
How can I achieve it?
You can change the highlight color in Options>Appearance>Colors. You cannot eliminate the highlight though… How would you know what you have selected?
You could try setting the highlight color to the same as your background color, the highlight will be pretty subtle or even more or less invisible that way.
Hello - can you please message me via private message with your V6 license key?
And can you please run SystemInfo in Rhino and paste the full results here?
A little late to the party here but I too need to sometimes not have the object highlighted, specifically when I need to place several reference points on a target mesh object. The yellow highlight makes it difficult to see the mesh precisely.
My original workflow that lead to it being undesirably highlighted yellow was:
Points → Persistentonmesh → SelMesh
What works for me now is:
Points → Persistentonmesh → (manually select the target mesh)
encountering an issue similar to @danny1 . sometimes when I’m using CrvBoolean or even Trim, it’s hard to tell which curves i need to keep, so it would be nice to not highlight the selected object, or to change the highlight to relate to the display properties of the selected object.
is it possible to set a selected crv’s color to the color of the crv?
alternatively, is it possible to give crvs a silhouette when the thickness of the crv is greater than 1?
Very interesting thing happened! The display color change was keep resetting to yellow after session is ended (close the program). I restored the faults in Shaded and it stayed changed hahah I don’t know how but It worked
