Hi there guys,
Is it possible to change the appearance of a selected item? I mean, I know I can change the color of the selection…
or using the key properties (Rhino.Options.Appearance.SelectedObjectColor) or the direct option on appearance…
But what I really need is not changing the color, but change a line stroke or something like that. Is it possible to use the selection color the same as the object’s color and use a dashed line stroke? Even in shaded object it could be a dashed line aspect? I mean a lot of times I have objects to center on other references and I always need to extract edges from the obects to center, then I hide the selection, I just use the new edges over the references to move them so I can see clearly what I need and when centered, use the original objects where I extracted the edges to put over those edges (already centered over the references)
I think that if i had a selection line style to customize could be much more effective.
Many thanks!
