I’m running into an odd problem. Maybe, it some change in Rhino 8 that I’m not familiar with.
When, I’m in, say, shaded or ghosted mode, object’s display colors show correctly by layer, but when I select an object, and try and change its display color manually in properties, I get 4 options:
By Layer
By Parent
By Material
Custom
When I select Custom, no color-selection dialog appears and the color just changes to white or something similar. (I can’t tell which color because there’s no dialog.)
Accordingly, I can’t individually change an object’s display color as I like.
It used to be that, in properties display color, I could get a dialog with the standard display color options and I could select any color I wanted manually for any selected object’s display color.
Please help!
Cheers,
Dave
