How to change Arc command default?
Hi
Is there any way to set the default option for the “Arc” command to the Arc option (start,end, point on arc)? I use this option the most often and find it inefficient to constantly enter in “s” after the command. If anyone knows how to set this up or can point me towards some kind of answer it would be awesome. Thanks!
use a macro version, put it into an alias or make a command.
_Arc _S
thanks!
