There is probably a very simple answer to this question:
rs.Command("_Arc 0,0,0 0,10,0 10,0,0") dont return an arc.
I have found out that the last instance (the end point) is for me always reprecenting an angle, and not point as I would prefer.
How do I change the last instace to point
I want to achive the black arcin picture below.
Your options resulted in the red arc.
I can’t find any easy rhinoscriptsyntas method for this so I thought that the rs.command() whould be the best option.
Do you have any other suggestion? Otherwise I will have to rewrite the program alot to make this work.
Thanks for the help Mitch!
Well, there is no direct Rhino command for arc from Center, StartPoint, EndPoint because there are an infinite number of arcs that can be built from these 3 points - it lacks a radius definition. So either you want to define it with Center, Start, Angle, or Start, End, Radius… The problem with the second is that there are two possible arcs, so you manually need to decide (Rhino makes you click on the screen). That makes it tricky to macro, but it’s possible.
You can program that either with rs.Command() or use the native rhinoscript syntax method rs.AddArc(plane, radius, angle_degrees). If you use the rhinoscriptsyntax method and you only have the center, start and end, you will need to do a bit of calculation first.
