Hello All - Is there a way to make an _Arc quick key that gives you _Arc: start, end, direction at start
(This does not work)
Below is the arc I want the function of when I hit ctrl_A at the moment its going to point on arc option
Hi - to create a macro that you can use in a button or keyboard alias, you need to use command options exactly as you would on the command line and add “pause” for mouse-clicks:
Arc StartPoint Pause Pause Direction
Thanks alot It works YAY
I was trying to find a tutorial but nothing was specific
can you p[lease explain what is ! and ’
all quick keys Ive just been copying and pasting from the commandline
Thanks again
I know you solved the question but now im trying to work out what you mean the commandline for the tool is below
You sent me
where did you get “direction” from
Hi -
When you go through the entire command and then look at the command history, you will see all settings:
For a complete overview of these, see:
https://docs.mcneel.com/rhino/6/help/en-us/index.htm#commands/macroeditor.htm
Thankyou yes I need to pull my commandline viewport down a bit I’m only seeing 4 lines
Thankyou again for your timely response and time getting the info to me Wim, cheers Jimi
Thankyou yes I need to pull my commandline viewport down a bit, I’m only seeing 4 lines
Thankyou again for your timely response and your time getting the info to me Wim, cheers Jimi
You do realize that the command line has scroll buttons at the right edge? Between setting the number of lines showing to suit your preference and scrolling you can see the whole command history.
Hey thanks yes I did but I usually only use the commandline for the command Its the first time I’ve had a good scroll through and look at the script for the macro
Thankyou again
