Where to start?
Thanks but still not sure. I assume you revolved the middle and sweept the outer “wing”? The middle is it’s a spline-ey curve. Did a straight axis give the curvey shape, or did you manipulate with points?
yes, Revolve with Deformable=Yes and then I edited the points a little. it allows to play with the shape a lot.
I’d probably just start with a sphere and do a bunch of bounding-box cages and just pull it into that shape.
shape.3dm (480.8 KB)
