How much RAM can I spare for undos?
Hello there,
I would like to ramp up the amount of undos I have in Rhino 7.
Currently I am running Rhino 7 on a 32GB RAM Laptop, the default storage in the the general settings is set to 1024 MB. How much can I ramp up this number in order to have no issues while working.
I usually dont exceed 3-4 GB of file sizes.
Is there a general answer to this or is it try and error?
Thanks in advance - Sebastian
Hi Sebastian - I’d say up to 10% of RAM might be OK. What problems do you run into, are you editing massive meshes, or something like that, where one change can eat up a lot of Undo?
Alright i will try that, that would be a 300% increase of undos if my simple understanding is right.
I only touched the border of undos when I wanted to go way back, and after 30-40 it stopped. Which is already alot, but the more the better I would say :slight_smile:
I will provide feedback once I tried the 10% for a while.
  • Sebastian
I often run two instances of Rhino and copy/paste some of the objects that I might want to bring back later. Creating a separate layer to copy your objects before you start chopping them up helps also. I call this my spare parts layer.
Hi Sebastian-
Keep in mind : UndoMultiple.
