Does Rhino 7 have a fixed number of undos?
During the work (undo) did not go back to the beginning of the work, so all the data is corrupted.
- File operations or changes made to viewports or construction planes cannot be undone by the Undo command. Use the UndoView command to undo changes made to the view.
- The number of commands you can undo depends on the memory size reserved for undo. Change the undo options in [General Options](https://docs.mcneel.com/rhino/7/help/en-us/options/general.htm).
To change the memory setting for Undo:
Options
> Rhino Options > General > Undo
I set the memory value to 10Gb, but I asked because the data went away.
Hello - the number of undos depends on the geometry and operations - if you make one small change on a huge mesh, the entire mesh must go into the Undo - this can, potentially, fill up the available memory quickly. If you are making lines, the amount of memory used is small so more steps are possible.
It was 40 megabytes of data and I worked for 1 hour. I don’t understand.
Do you have Autosave enabled? If so an auto-saved version may be available in the designated file location for Autosave or in your Windows Recycle bin.
Hello - please run SystemInfo
in Rhino and Copy/Paste the results.
Rhino 7 SR3 2021-1-26 (Rhino 7, 7.3.21026.13001, Git hash:master @ 33003e99b55b3e99bc54b233a1b4cfd15b4a8ab2)
License type: Commercial, build 2021-01-26
License details: Stand-Alone
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2080 (NVidia) Memory: 8GB, Driver date: 12-31-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 461.09
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-31-2020
Driver Version: 27.21.14.6109
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.3.21026.13001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.3.21026.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.3.21026.13001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.3.21026.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.3.21026.13001
