Hey,
What would you recommend for the “Min number of undos & Max memory used (MB)” settings ?
G.
Hi Gil- Min Undo should be 1. Memory allocation should be something that makes sense with your system - but in genreral perhaps 10 % of available RAM might be a starting point. Minimum Undo has been removed from the UI for V6, it makes no sense - only RAM should count.
Tnx @pascal,
Ill set the “Availble RAM” to 1.6 GB for a 16 GB of RAM on my pc.
