i don’t know why the trimmed suface(no matter i use a curve to cut/pushpull)does not fit the outline where it supose to be. is it because of the angle tolorence or the unit?i already set the angle tolorence to 1degree and also tried to exploed the whole polysuface and use refittrim command, it worked a bit but when i rejoin the sufaces into a polysuface it turned out also bad.
is there anyone knows how to fix this? all i want for chrismas is a smooth fit polysuface model.
thanks
To expand on @David53 reply: When Rhino displays a shaded or rendered NURBS surface it actually displays a mesh created from the NURBS surface. This mesh is called the “render mesh” of the surface.The kinks and gaps you are seeing between the displayed surface (actually the displayed render mesh) and the input curves is because the render mesh is too coarse for the view magnification you are using. The actual NURBS surface is smooth.
The render mesh is controlled by settings in Options > Mesh. Try changing to “Smooth and Slower”.
