When I use the Blend command, I can grab a control point and tweak it before I accept the command result, but I do not see the same for the Match command.
Am I missing something semi-hidden again? (I consider anything in the command line thingy hidden.)
Hello - The hidden thing is to make your match with History on (I find that âpreserve isocurve directionâ gives me the most flexibility in editing) , then noodle it after the fact to tune up.
Hmmm - not sure what you mean - see the attached file - blue is matched to red for curvature - I can mess with the points on either surface and the match updates.
@pascal A surface version of EndBulge would be very useful. EndBulge allows adjustment of control points of a curve whjile preserving the curvature, tangency and position at the ends of the curves. Use Match to create the initial end conditions of the curve, and then use EndBulge to modify the curve as desired.
So you can. And on 6.16 so can I, it turns out. Was this a recent change or is this a setting I may have inadvertently activated on the other computer that makes it so any move breaks history?
One thing that is lacking, though, is the Alt modifierâs ability to change the Angle of a surface blend.
A surface match is no different, and should really have the control points show up when the tool dialog is open, so I can change the angle of the matched surfaceâs edge with alt as well (a workaround is to manually ânoodleâ the control points and then choose âpreserve isocurve directionâ, but the discrepancy in the user experience between the Blend tools and the Match tools is jarring to me).
What comes to mind is that the History on MatchSrf is limited to one edge and you may have had another edge matched - though here I do not get a warning, actually, it just stops working for one of the edges.
Yep, I do not disagree ⌠more controls would be nice - some unifying of the interaction of BlendSrf, MatchSrf and EndBulge would be a good thing to look into as well.
Iâm curious, since Rhino doesnât have a very deep or robust History, and people probably start out with Blend surfaces but then most likely modify them at some point⌠wouldnât Match be more used than Blend by users, or is there a workflow Iâm unaware of?
