(WIP) matchSrf Wishes
i am hoping for a nice update on _matchSrf in Rhino 9.
my wishes - unsorted:
  • a new UI, that is coherent / similar to _fillSrf, _edgecontiuity and others - a list that can be modified until everything is set up correct, skip the old linear UI concept
  • multiple _matchSrf should cascade on one surface with history / and or
  • a copy option, that allows history for a cascade of multiple _matchSrf for advanced “massage” tequniques
  • constraint and lock CVs / better isocurve control
  • limit CV-movement by distance
  • turn on CurvatureGraph and/or zebra even if _matchSrf is already active (similar to _blendCrv)
  • show deviation
  • match G2, refine G0 only (meaning the amount of knots insert should only be definded by G0
  • refine with maximum number of Cvs / spans
would be nice to see some improvements.
@Rhino_Bulgaria already posted a lot of important
aspects to make this tool up to date.
(maybe post some links / wishes below?)
thanks for some updates on what is planed for RH9
kind regards -tom
This is one of the things that always bothers me. I do the following workaround. First, I match with G0 and the “Refine” option, then I delete the History (I keep it active all the time) for that very surface, then I apply another run of “Match surface” either with G1 or G2, but this time without the “Refine” option. If I match directly to G2 with “Refine”, quite often Rhino adds way too many unnecessary control points.
As for your request for including links:
i do the same… annoying workaround.
another option / workaround:
_matchSrf G2 without refine but with history on
optional _pull the edge with history on
_crvdeviation - _insertknot … repeat until G0 is reached … but this feels more like craftsman sculpting a stone then cad defining a proper nurbs surface… :hammer:
thanks for the links
I also do that other workaround, but it often needs undoing and is time consuming to figure out what’s the neat distribution of the newly added spans.
The biggest flaw of the current “Match surface” is the inability to match with G2 by moving the 3rd row of control points in the normal direction only, thus preserving the intended flow of the surface.
Another missing feature is the ability to individually match the start edge and/or end edge to inherit tangency from the target surface’s side edges, especially if they are trimmed.
Individuall matching to U direction or V direction is another missing feature. Currently, the “Match surface” tool has a common option for UV direction that produces ugly and unusable output surfaces.
I’m certainly with you that a non linear workflow is preferred. We are first attempting to Implement this idea into FillSrf, since it is a new command and has no legacy to deal with.
Now it’s time for the “Match surface” to be vastly improved in Rhino 9. :slight_smile:
If you want that, then please shout out loud to @pierrec
It would be my personal wish as well that MatchSrf gets some love.
Does that mean that we have to tag @pierrec for every request regarding “Match surface” and “Blend surface” to get a better chance that they will be read by the proper developer?
that’s correct. MatchSrf is on his list.
ps: I did an extensive investigation into MatchSrf issues a while back. These are all the open issues. Let us know if something is missing:
https://mcneel.myjetbrains.com/youtrack/issues?q=%23matchSrf%20state:Open%20
OK, I will make sure that he is tagged in my requests, future and old ones. :slight_smile:
Over the next few days I will check the list you posted above.
Yes please blend surface
:folded_hands: @pierrec :folded_hands:
This 12 years old MatchSrf problem is critical also.
Please support matchsrf wishes
All my support for MatchSrf improvment.
I think they’re working on this.
