Hey guys
I have designed a form which is extrusion and have moved it, I know you can create a facade/texture going down the mesh route but how about a geometry?
Any help please and thank you
Hey guys
A more detailed question please..
if i understand your question correct you can use displacement in rhino and extract the resulting mesh, i dont know how that would work in grasshopper though but i am sure its feasible similarly.
I want the form I created (image 1) which is a ‘geometry’ not ‘surface’ to have some sort of texture, so I want to know how (using grasshopper) i am able to manipulate the facade of image 1 to have the texture like image 2
IMAGE 1
IMAGE 2
A couple of clarifications…
When you say texture are you meaning an image tiled as material?
https://docs.mcneel.com/rhino/7/help/en-us/index.htm#commands/textures.htm
This goes on the complete ‘form’? or just vertical wall-like surfaces?
What is the end goal? (Rendering, Fabrications, something in between)
