I want to create this surface without using patch because patch doesn’t allow it to be smooth for me to join it with the body of the volume I duplicated the edges from a mass which does not allow me to cap it do to the shape of the curve. Any suggestions?
Hi Cameron - please post file with the curves.
Hi Cameron - if you set up the curves to be one that has an angle, and the single line opposite, then a Loft will get you the polysurface I think you’re after.
Okay, thank you!
