I testing Enscape and run in an old problem - how can I edit materials created with an other render plugin? For example I have a Octane scene and like to work with Rhino render materials. The materials are blocked, I can’t edit the materials. I want to keep the texture paths and adjust the settings at basic Rhino material level. I hope there is a way.
Could a conversion to Rhino materials be done if the plugin is installed? For example I have an Octane brushed metal, at viewport it looks good, also at the Enscape rendering. Since Enscape is using the Rhino material data I suppose so the basic Rhino parameters are right set. Only I want to adjust it at Rhino level.
Interesting could be that there is a context menu command “Change type (copy similar settings)”, but it doesn’t work, textures are reset. Should this function do the job?
An other problem is, if a client send me a scene where he used an other engine than I can see textures and colors at the rendered viewport, but can’t edit them. I like to get access to the Rhino materials only. So, who can I ask for the Rhino render plugin to open the access to the at the viewport current used materials?
