Hello I’m jeong!
I am trying to wrapping pattern(curve / polysurface) on curvature polysurface. but it is not easy to keep align of pattern.
for now i project to top and side view then matching the line by hand… I feel like super dumb. could you give me some advice to me? I am desperate.
One way is to create a single surface that’s ‘pretty close’ to matching up with the area that you want to apply the pattern on, with even spacing of points. Then create a planar surface with same point structure under your lines. Then use Flow. After flow, use Pull to finish up.
